I saw this
Originally posted by rbnvrw I recently bought a K1000
And I went back and read again...
Originally posted by rbnvrw I recently bought a K1000 and now that my first roll came out quite nice
...and realised it wasn't a typo. If I'm reading this at all right, the OP has a FULL-FRAME FILM CAMERA and can't even use all the features of a K-A mount lens, so why are some people here talking in terms of digital photography, DA-type lenses and autofocus? In book terms, he needs photography guides that are
not less than 20 years old, and preferably older.
To the OP:
I would forego the fisheye in the first instance; it's too specialised. A good starter kit is a 28mm f/2.8, a 50mm f/1.8 or thereabouts (which you've already got), and either a fast (e.g. f/2.8) 135mm prime or a good-quality zoom in roughly the 70-200mm range (give or take 10mm at either end). I recently acquired (and have taken a few pictures with) the K-A version of the 50mm f/2.0, and it turns out some damn good results. You could perhaps consider investing in a faster 50mm
in the long run if you really needed the extra stop or so, but once you get faster than f/1.4, things get very expensive very quickly for any lens still in good condition. Also, focus becomes critical as depth of field is razor-thin at close distances, and even small objects can be partially out of focus.
If you want a true macro lens, add it later. Some zooms and a few prime lenses offer close-focus capability without the magnification, or you could start reading up about extension tubes, reversing rings and/or bellows.
An
authentic Pentax M42-to-K-mount adapter (no longer manufactured, but e-bay has them) would also not go astray, as this can really broaden your options in terms of acquiring suitable older lenses. Among other things, the later generations of these oldies offer a manual mode with forced stop-down built into the lens. Very handy if you need to know what your depth of field is going to be, because the K-1000 has no stop-down lever AFAIK. Also, the optics on some of these are of near-legendary quality.
