05-20-2015, 12:54 AM   #1
oversea's Avatar
vintage Konica lens
Hi
One friend gave me some olds konica lens and I was very curious to see how it works on the K 50. I see here that a Q will be better but It was for my curiousity.
so I order an adapter fotodiox for thes test.
so the first shot with the 100m
as you can see on the last photo I have an halo effect, and I would like your advise ,is it to much light problem on the sensor , I have the same problem with the 57 mm
the lens range is 100 mm / 55 mm / 57 mm and 80 / 200 . the photos under are with the 100 mm
Thanks a lot for your comments.
Cheers
05-20-2015, 04:19 AM   #2
Lowell Goudge's Avatar
I had a similar halo on an old token on 135, which I thought we election off the rear element, and sensor, but in the end I tracked it down to a part in the lens, specifically the retaining thread in ring for the rear element, which was shiny anodizing, as opposed to being dull black. I repainted the retaining ring with hobby paint (water based) and the halo disappeared. Others have had similar halos with bright shiny silver parts in third party 645 and 6x7 adaptors. Look in the lens to see if there are any nightly reflective parts behind the rear element
05-20-2015, 09:06 AM   #3
I had the same problem with one of my lenses. Pretty much the same lighting situation shot @ f8 to F11. Problem solved by using deep hood.
05-20-2015, 05:08 PM   #4
oversea's Avatar
Many thanks all for the comments , I will try with deep hood and also I will check also the lens.
thanks
k-mount, konica, lens, mm, pentax lens, slr lens
Abstract Vintage Camera for Vintage Cruisers jgblodgett Photo Critique 6 01-11-2015 07:21 PM
Thematic Vintage Feelings - Post your vintage shots schnitzer79 Mini-Challenges, Games, and Photo Stories 15 12-02-2014 06:50 AM
Konica lens problem... unixrevolution Non-Pentax Cameras: Canon, Nikon, etc. 2 12-15-2009 06:18 PM
Konica lens for Pentax? Panache Pentax SLR Lens Discussion 5 01-26-2008 09:55 PM
All times are GMT -7. The time now is 11:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
