Originally posted by jake14mw Pentax 16-45 f4 – Probably the front runner right now? Good range for me, inexpensive. My main question is, how is the IQ at the wide end?
If by IQ you mean lens sharpness, the 16-45 is plenty sharp across the frame at 16mm --- indeed, surprisingly good for a zoom lens at its price point (assuming you don't have a decentered copy -- always an issue because of the barrel wobble). I became a bit dissatisfied with my DA 16-45 as it was struggling to keep up with most of my other glass. While it's a nice lens and definitely superior to the DA 18-55, I would rank nearly all the other DA standard zooms above it. Even the DA 18-135, despite the weaker edges at the wide end, produce images that
look better thanks to superior lens contrast.
If you really like what you're getting the Tamron 28-75 you may be best off getting the Tamron 17-50, as there should not be much difference between how each of those lenses performs.
