Originally posted by Okami Are my lenses all too short??
I have no idea the distance of the riser to the walks and other areas to shoot. I've been to a few shows but never had press credentials.
That information will be KEY to choosing the correct lenses! Find out where the venue is and google the floorplan if available. If the events are anything like what I've been to, you can forget about a tripod. Even a monopod will be of limited use. Would have been a bother when I did this stuff.
Your lenses should be long enough, the 135 zoom should do nicely if you're on the photographers platform. The whole deal with this type of photography will be your timing. You'll want to be dialed in on the spot where the models stop and strike a pose. Usually two or three spots on the catwalk.
If you are shooting all the models, pick and dial in a spot where they strike their poses. If you have a choice to concentrate on your friend, you can zero in on the top of the walk, shoot the first pose, re-focus at the end of the walk and when she reaches there and strikes her pose, shoot again.
I was fortunate that the event coordinator placed some tape to block off the areas where the models were to stage & pose. Made setting up the focus before hand easy. The pace was fast, but ordered and predictable.
