Originally posted by ramseybuckeye ...The catalog has many Pentax items...
You work somewhere nice
The DA 50 sounds like the correct choice for you, as you prefer AF and you think you would get the most use out of it. I'll comment on the other choices, though.
The 8mm fisheye has such a deep depth of field that AF doesn't matter much. Use it hyperfocally; manually focus 2ft away, stop down to f/8, then everything from 1ft to infinity will look in focus.
The 85/1.4 is on my shopping list but for astrophotography, not portraits. Samyang lenses are known for having minimal coma distortion and that helps stars look sharp. If you have the O-GPS1 astrotracer already it would be a good way to get zoomed in shots of busy portions of the Milky Way. This sample is a similar focal length but with a less good lens:
