I got this lens pretty cheap, but the diaphragm blades are too slow to use any aperture other than wide open.
I got a book from the library called
camera maintenance and repair, which has a tiny bit of info about cleaning blades. I have run into two problems so far.
I don't understand how to remove the front of the lens.
The screwdrivers I got from the hardware store are softer than the screws in the back of the lens, and I am mangling both the screw heads and the screwdrivers trying to get the screws loose.
Does anyone know where I can find:
- A link to pictorial info on taking the front of the lens apart
- Good screwdrivers that will grab onto the screws so I can get them loose
Any other links/bibliography/advice? I want to do this myself, even if it ends up being a learning experience that hacks the lens to death but gives me enough understanding to do it right next time.
