06-10-2008, 07:48 AM   #1
notion's Avatar
Can you use the lens hood from the DA 70 on the DA 40?
I have the DA 40mm limited lens. The lens has been a favorite of mine due to its size. While I like the small lens hood, I really dislike the screw on lens cap.
I was wondering if you can take the lens hood from a DA 70mm limited lens and use it on the DA 40mm lens. They both have a 49mm filter size. If it would work, do you have an idea where I could buy the lens hood?
06-10-2008, 08:51 AM   #2
Torphoto's Avatar
I would say no, as the hood on the 70mm is designed for it's FOV, the 40mm is wider and would probably cause problems with it's FOV with that hood.
06-10-2008, 12:44 PM   #3
I put the hood from my 70-200mm f/4 IS on my 17-85mm (both 67mm threads), and it vignetted like crazy @ 17mm! I know, an extreme example, but I'd think you might have some problems with 40mm vs. 70mm.
06-10-2008, 03:18 PM   #4
AndrewG NY's Avatar
I imagine that the hood/cap from the FA43 would work better but perhaps be less effective as it was designed for film angle-of-view coverage. There are probably some decent third-party metal hoods that would work well but finding just which one would work best might be a little tricky especially if you want to fit a lens cap over the end. Replacement hood & cap for FA43 would be pretty simple if not cheap.
Another possibility--stack a few 49mm filter rings (no glass) such that you get some protection but not so many that it vignettes. You can then use a standard 49mm lens cap. Perhaps there is some sort of similar glass-less step-up/step-down ring that might work similarly.
06-10-2008, 04:36 PM   #5
Notion just get this 30mm clip on cap.
06-11-2008, 09:43 AM   #6
volosong's Avatar
QuoteOriginally posted by Rico Quote
Or, just use the cap from a Fuji film canister. Works like a charm.
06-11-2008, 10:08 AM   #7
I use this hood on my 40mm DA:
B+W BWLHM49 49mm Screw-In Metal Lens Hood #950
Got it from B&H. No vignetting with any filter, including polarizer (Hoya). It's designed for use with a 50mm lens but the 40mm DA is equivalent to 60mm so no problem.
For caps I use this, also from B&H:
Pentax PELC49AF 49mm Snap-On Lens Cap
40mm, da, hood, k-mount, lens, lens hood, pentax lens, size, slr lens
For Sale - Sold: Pentax Rectangular Metal Lens hood for 58mm Lens (Worldwide) oneill Sold Items 2 03-19-2010 05:12 PM
For Sale - Sold: Pentax 18-55mm lens hood with box (no lens, just hood and box) drabina Sold Items 3 09-13-2008 06:21 PM
All times are GMT -7. The time now is 07:33 PM. | See also:, part of our network of photo forums!
