Note: I resurrected this old thread of mine since my new post sort of follows on from it. New posts start about 8 posts down.
Here's a question I can't work out the answer to.
There exist tilt and shift adaptors for medium format lenses (say pentacon six), to 35mm mounts such as pentax-k. This means you can use MF lenses on full-frame, as it were, sensors, or film equivalent. Obviously there is a slight issue of the lens length - a 30mm lens at MF is a fisheye, whereas a 30mm lens designed for a full-frame camera is not.
You can also, of course, then use the same lenses with adaptors on aps-c sensors, but because they are two size-formats smaller, as it were, the effect of the lens lengths / crop factors is greater.
Why, then, can you not use lenses designed for 35mm cameras, with suitable adaptors, as tilt/shift lenses on aps-c cameras - why must you use lenses which are so much larger in format. Clearly when I use an old pentax lens on my dslr I'm cropping in on it by x1.6, meaning there is a whole periphery of glass, and of decent image, which I'm wasting.
Is there a reason an adaptor can't be made to allow "normal" lenses to shift or tilt on digital bodies?
Reason: Because I brought thread back from the dead.
