Originally posted by connor.nolan Ok looks like the consensus is that an UWA lens is necessary. However I don't quite have the money for the Pentax 15mm or the 12-24. Would I be better served with something such as the tamron 10-24 or would the Pentax 35 2.4 be more useful?
eeeeeeeeeehhhhhhhhh, an UWA lens is not necessary. It all depends what you want. If you like the look of UWA, then yes get one. if not, then there is no need. In the small crowed streets of Europe there really is no need for an UWA. Just adapt yourself to the lens you have, and you will get good shots. And if you want to emphasis the crowed small streets, an UWA is not the one you want, you really then want something longer. More in the line of 50-70mm
