06-11-2008, 06:02 PM   #1
Question About Auto/Manual Switch on Vivitar M42 Lens
I have a Vivitar 28/2.8 Auto lens, and am not familiar with the auto/manual switch it has. It is not the slide type of a/m switch. It has a ring with an "m" with an arrow pointing at it. How do I switch back and forth on this lens? I have fiddled with it a bit, but I do not want to force any of the controls.
Thanks,
Glen
06-11-2008, 06:31 PM   #2
maxwell1295's Avatar
You should be able to slide it back and forth (it may have to be mounted on the camera first). To use it, you should set it to M and use the aperture ring to for aperture adjustments. No need to stop down with these lenses.....just shoot in Av mode and all you have to do is focus and shoot. That's worked for me with every M42 lens I've used. They're actually easier to use than M lenses. You will probably need to up your EV comp to +2 since these lenses seem to consistently underexpose.
06-11-2008, 06:49 PM   #3
The problem is that I do not see a slide switch (as I have on my other M42 lenses). I see some type of nub on the ring. The nub has a small metal (chrome) lever that can be pushed in. There is also a grooved lever that looks like a wheel--that is, the top portion of the wheel comes through the barrel of the lens. This wheel-type thing is next to the arrow and "M," and is behind the ring.
Thanks,
Glen
auto/manual, k-mount, lens, pentax lens, slr lens, switch, vivitar
What "AUTO" on a manual focus Vivitar lens? emr Pentax SLR Lens Discussion 5 08-06-2010 09:56 AM
SMC Takumar 85mm 1.8 Auto/Manual Switch Jammed Irishwiseguy Pentax SLR Lens Discussion 12 06-29-2010 11:36 AM
How to fix a auto-only M42 lens so it becomes a manual one sterretje Pentax SLR Lens Discussion 5 05-16-2010 10:12 PM
auto/man switch question BernardMarx Pentax Film SLR Discussion 15 06-15-2009 12:11 PM
Vivitar 28/2.8 Auto (M42) zx-m Pentax SLR Lens Discussion 0 06-06-2008 11:21 AM
All times are GMT -7. The time now is 05:20 PM. | See also: NikonForums.com, part of our network of photo forums!
