Just received a DA 16-85, which will be replacing my DA 17-70. I did a few quick snapshots of the DA 16-85, just to make sure it was not suffering from obvious issues. Just for fun, I took similar shots with the DA 17-70, to get sort of a tentative indication of how they compare. I would not, however, make any definitive judgments from these crops as to the relative merits of these two lenses. To really get to a know the strengths and weaknesses of a lens, one has to use it under variety of different lighting conditions, photographing a variety of objects of different colors and textures. All images shot at f8. Shot in Raw, using embedded profile in Lightroom.
To begin with, at the wide end of lens (center crop), with the DA 17-70 on the left, the DA 16-85 on the right:
Very little difference here, beyond slight contrast advantage for the DA 16-85.
Two more crops, one bottom middle, the next far edge crop:
The DA 16-85 does look a bit sharper here, but if you were looking at 20 inch prints at normal viewing distance, I doubt you'd see a difference.
Now for crops at ~24mm, starting with center crop:
The DA 16-85 does look a little sharper here, but I suspect what we're really seeing is more contrast.
Edge crop:
Very slight and utterly insignificant advantage for the DA 16-85. Both lenses are very good at this focal length.
At ~35mm:
A little more difference here, all in favor of the DA 16-85, but still hardly rising to the level of significance.
At ~50mm:
The DA 16-85 pulls ahead a bit more, but pixel peeping exaggerates by how much.
At ~70mm:
The achilles heel of the 17-70 was always at the long end, so it's no surprise that the 16-85 out performs it here.
The DA 17-70 is, optically, a very nice lens. The DA 16-85 would seem to be slightly better: better contrast throughout its range, ever so slightly sharper at the wide end, definitely sharper at the long end.
