Hi,
Thanks so much the info.
Pentax K+ Multi-Mount (WR version) - Adaptist says they support WR as well.
What are the downsides of this when compared to leitax method ??
Also my lens is not a MM it seems as the smallest aperture value is not in green.
Also along with the 85mm lens i also bought the 2.8/135mm 2.8/35mm and 1.7/50mm lenses.
That's one of the reason why i am inclined to get a multi mount. so that i can use all these lenses without modifying them (unless there is noticeable degradation in quality).
If i need to modify each lens then i have to modify all the four. (i guess if i can modify one i can modify the others easily :-))
Any suggestions reg whether to go with multi mount option or replacing the mount on each lens.
Thanks
