Originally posted by trevorg I think most DA lenses are best suited to auto-focus.
Yes, definitely. Many don't even have an aperture ring. They are part of the "digital" trend, where everything is electronic and gets chosen on the camera. And this leaves a lot of us wishing for lenses with aperture ring, generous focus throw, and so on. Short focus throw is good when you use AF, though, because it means AF is faster. The FA series probably has a longer focus throw than the DA series, but still not as long as A and older. But it would be interesting to see actual measurements.
Originally posted by trevorg A100mm/2.8 (Has a massive throw)
Yeah, pre-AF lenses have a precise, long focus throw. And macro lenses have an extra focus throw in the macro range. This is why I recommended A 50mm f1.4.
Originally posted by trevorg the 43mm. Is the 43mm suited to portraits or is 50mm the minimum?
Some say portraiture is minimum 55mm for the "face only" type of photos. But you can take portraits with 43mm, especially on APSC gear or if you are taking full body or environmental photos. Some use 35mm for this, so 43mm should be fine (The FA ltd is a special lens, has lots of character, so its a good choice for portraiture. But FA 77mm is probably even better for this purpose). You can check the user lens reviews section or the sample photo gallery. Still, I think an M or A 50mm f1.4 would fit your needs better. With A series you lose only AF. With M series you can use Av mode for wide open photos or M mode with green button metering. Oh, and with (most) manual primes you can use the function called Catch in Focus. This gives you something similar to AF.
