Originally posted by fredralphfred Do you mean it wiggles around when you swing the camera? Or do you mean it can slide crooked if you're not careful?
I don't have a 77, but I've got an M200, an M135, and a DA 70, all with slide-out hoods. If I pull them straight, they're straight and they stay put. It's possible for them to get a bit crooked if you're not slightly careful. Perhaps they have a "nicer" mechanism in the 77?
Thank you for your response. It doesn't wiggle when the camera moves. It stays straight when I pull out but moves around to a crooked position easily. I think the 77 mm may have a stiffer mechanism. Thank you again!
