You can buy a filter that has bayonet lugs so that you can add a bayonet hood lol
You can get an original pricey one, but I wouldn't pay that much for it.
Another thing to keep in mind is where the lens will be used. On an APSC camera, you can add a much tighter lens hood, get more protection, and have no issues.
What I would suggest is you get a JJC or Mennon or whatever brandless lens hood that fits the filter threads on that lens. You can get a nice round one for a low price. Rubber ones can be good, too, because you can set them to different lengths and some have filter threads on the end as well. You can get a telephoto petal hood, it looks cool, but its not as optimal. Personally, I got a JJC PH-SA49 replacement, even though its a bit "wide". The square fits with the Pentax theme. But its a clip on hood, which has some downsides, but its faster to mount than some screw-on hoods. Take a look at Mennon A-S 49 and Mennon DC-s 49. Regarding material, I would choose plastic over metal. Metal can be shiny and if you bump it, it can transfer stress to the lens. I prefer the hood snaps and breaks than the lens!
Choose based on your needs.
Btw, some people even use a step down ring or two as a lens hood, similar to how some DA Limited lenses have those pancake hoods. Just make sure the opening isn't too small.
Edit: Thing is, a native square hood will be the most optimized and best. Native petal/tulip/crown hoods are good as well. But if it doesn't fit the specific camera, focal length and aperture, then its not optimal, might even have weaknesses, and its not super cheap. This is why circle hoods are fairly good, because even though they are not optimal, they fit pretty well on almost anything, have few weaknesses, and are generally pretty cheap. Vented hoods are for rangefinders. I wouldn't pay over $20 for a hood, unless it was for a very unique lens
