Originally posted by dtmateojr Again, nobody asked for a definition. EVERYBODY knows the definition.
I did not provide a definition, I asked you a question.
Instead of answering my question, i.e., instead of clarifying what you really want to know from me, you repeated your statement about why using formulas is not the same as understanding something. We cannot make progress like this. If you debate properly, you will be cornered into realising that you are basing your conclusions on fundamental misconceptions. I'm foolish enough to think that I may succeed in letting you realise your fundamental mistakes, despite the fact that entire threads (
here and
here) were dedicated to make you realise your misconceptions, in part by very knowledgeable people (one of them is responsible for the very useful
sensorgen website). FYI, I never participated in these threads, something you seem to assume.
So if we don't want to create a third thread like that, you'll either have to answer questions or I'll have to give up. I had given up earlier when I said it was time for me to leave the thread but then I thought of two aspects that may help some people to understand what is going on. It is my hope that someone yet uninfluenced stumbling over this thread will read my posts and hence not fall victim to the misinformation spread by people who do not understand that exposure must not be equal across formats in order to achieve images that look the same.
Originally posted by dtmateojr The question is: do you understand WHY?
I do. And the result the definition gave me "f-ratio becomes smaller" which is exactly in line with what you stated later:
"It lets MORE light per unit area." -- dtmateojr
So in my
first answer to your question I already stated the same fact by saying that the f-ratio decreases. A decrease in f-ratio, as you know, increases the intensity of light.
So why did you have to repeat your question? What you should have done instead is to read my explanation as to why an increase in the intensity of light does not matter (when you decrease the format at the same time).
I already explained that for image quality the main factor is the number of photons captured because the more photons we capture, the lower the shot noise. Everyone knows that through the fact that longer shutter speeds or wider apertures reduce the noise in an image.
Now if you capture the photons gathered by a lens, it does not matter what registration distance a lens has. You can capture all photons, e.g., 50mm behind the lens with a sensor that is 50mmx50mm large, or you can do it 100mm behind the lens, with a sensor that is 100mmx100 large. We have to increase the sensor size as the light emanating from the lens will spread.
Do you understand the difference between "registration distance" and "focal length"?
It seems you don't.
Do you agree that we capture the same photons either way?
If you do, you'll realise that we are taking the same photo, either way. We are just using a different representation in-between, before we show the sensor data to the viewer.
Do you agree that the exposure (light / area) is different between the 50mmx50mm sensor and the 100mmx100mm sensor?
If you do, you'll realise that the exposure can be different but the image captured will be the same.
In fact, the larger the format, the lower the exposure must be.
If we kept the exposure constant when changing formats, i.e., if we said a 17-50/2.8 lens corresponds to a 26-75/2.8 lens on FF, then we would expose the larger format image so that we can print it larger than the small format image without additional noise showing. The latter is not necessary (and incorrect) for an equivalent image. Just because we are using a larger format, does not mean we want to print bigger. Hence we don't need to achieve the same exposure. We would be paying the price of less DOF anyhow, if we used the aperture to achieve the same exposure (i.e., if we used the same f-ratio on both formats).
Originally posted by dtmateojr Do you understand HOW focal length affects light?
Yes, and the definition of f-ratio I provided was in accordance with that understanding.
Originally posted by dtmateojr Because if you do understand, you would not have used a focal reducer to refute my arguments. It SUPPORTS the fact that equivalence is WRONG.
How so?
Please elaborate.
Please, before you answer, read my post here carefully and think about the irrelevance of the lens to sensor distance for capturing an image for how the image will look like, but that exposure depends on the lens to sensor distance (as intensity, i.e., light per unit area decreases the further away the sensor is from the lens). From this, it follows that exposure is not a good parameter to consider when you are concerned how an image will look like (in terms of DOF and noise) across formats.
