Originally posted by dtmateojr FoV is directly related to focal length. They are inseparable.
That's wrong in the context of discussing different formats.
A 35mm FF lens does not change its focal length when mounted on an APS-C camera, yet the recorded FOV changes. In other words, with respect to what is relevant, i.e., the recorded image, FOV and focal length are not "inseparable".
Do you see your mistake?
Originally posted by dtmateojr Another way of looking at it is using a property of focal length: magnification or the projection of the subject into the sensor. It's NOT about the image circle.
When talking about different formats, the size of the image circle is paramount. If you use too small a sensor and hence cut out much of the image circle, you lost signal samples, i.e., you will get more noise.
It really does not matter what focal length is used to create a certain image circle. If we want to make apples to apples comparisons then images we compare must have the same FOV anyhow, so it does not matter what actual FOV it is or what actual focal length was used.
All we care about is to always capture the full image circle.
Originally posted by dtmateojr Total light alone is totally missing the point.
What do you mean by "
total light alone"?
What is there more than
total light?
On the contrary, looking at
intensity alone would be missing the point. Because if you look at intensity (exposure) without regard for the size of the image circle, you are missing the point of how many photons were captured.
Your point of view -- that exposure is the be all and end all of photography -- would be correct if we always printed our images at a size proportional to the size of the sensor we captured them with. So Q images would make tiny prints and 645 images would make large prints. Only then exposure would accurately predict image quality because the lower amount of light used for a Q image could only be viewed in a tiny print in which image noise would not be observable to the extent it is on a large print.
Originally posted by dtmateojr Point is, decreasing focal length does brighten an image.
No, not if you keep the f-ratio and format constant.
Decreasing focal length does not brighten an image either, if you keep the aperture diameter constant and change the registration distance and format accordingly. The intensity gets higher, but the overall image brightness (intensity x area) does not become larger.
Originally posted by dtmateojr Point is, decreasing focal length does brighten an image. It lets MORE light per unit area.
More light per unit area, i.e, higher intensity only equates to a brighter image, if you keep the image size constant.
When talking about different formats, the image sizes (image circles) change. So more light per unit area does not mean a brighter image, if the image size reduces accordingly. A small, high-intensity image circle may look brighter than a large, low-intensity image circle but in terms of the whole
image they have the same brightness. You can record either version and when you print them to the same output size, they'll look exactly the same.
Originally posted by dtmateojr Heck, it lets more light in, period.
And this is exactly where you are 100% wrong.
Higher intensity does not equate to "more light". It only does if you don't change the image size. However, in our discussion image size changes. You are one of those people who equate longer focal lengths with larger image circles, right? If so, you must agree that decreasing the focal length reduces the size of the image circle. If you do, you'll realise that the higher intensity is just caused by the
same light now being condensed in a smaller area. In other words, there is not "more light". Do you understand this now?
