Originally posted by Rondec Then why do people show up on the Q forum to tell them how slow their lenses are? The goal of equivalence is to prove that no system is as good, or small, or as fast as a full frame system.
If you are referring to what I wrote in a certain topic on the Q forum, I only wrote it in response to reh321 saying it's equivalent to a 1400mm lens, without losing any light. I thought that was misleading. I mean, saying it's like a 1400mm lens is already applying equivalence, right? To my mind, if you apply it to focal length, you have to apply it to aperture too, because aperture (well, the f-number anyway) is a formula: f divided by some number. And f is the focal length, and you just said that's like 1400mm. The end result of the formula is the diameter of the actual opening in the lens. That doesn't change. So in order to make the math work, if you say it's like a 1400mm lens, you are also saying it's like an f/26 lens. Although ISO kind of loses its meaning in that respect. That's why I spoke of relative ISO performance. But ok.
You don't HAVE to say it's like a 1400mm lens though. In which case you can just dismiss all of this.
Also, I didn't tell anyone how slow his or her lens was. Telling someone how slow a lens is implies an opinion. I did not state that. It was interpreted as such, but that was not my doing. In fact I was surprised that f/26 seemed to be interpreted as some kind of offensive language or something.
Btw, according to DXOMark, the Q10's indicated ISO actually differs a great deal from the measured ISO (
http://www.dxomark.com/Cameras/Pentax/Q10---Measurements). ISO 3200 is really just above ISO 1600. So you have to take that into account as well when comparing noise performance.
edit: so, actually, if the above holds true, ISO 100 / f/2.8 / 1/100 will not get you the same exposure on a Q10 as it does on, say, a K-3. I still like my Q10 though.
