Originally posted by xenocide72 in some situations 500mm can be too long, but I am currently into bird photography which I find to be challenging due to the small size of the subject.
I hear you.
First of all a "bird", here in Eastern N. America, can be anything from a Ruby Throated Hummer (L 3.75", WS 4.5", WT 0.1 oz) to a White Pelican (L 62", WS 108", WT 17 lb).
By far the most common birds we will actually see will be small, nervous, fast moving woodland and grassland passerines about 1/3 the size of a man's fist - a house sparrow size for instance (L 6.0", WS 9.0", WT 1.0 oz).
So first of all, for the purposes of birding, forget about thinking in relative terms like focal length and use the absolute term
magnification. After all apparent magnification is what we are really ultimately after. I use the term "magnification" in the same same sense we use 8x or 10x "magnification" with binoculars.
It's been my experience when chasing after small woodland birds that their comfort zone is in the 30 to 40 foot range Get beyond 30 feet, set up, settle down and the birds will eventually accept your presence - no hide needed.
Assuming you define enough magnification at 35 feet so that a House Sparrow will take up about 1/3 the area of a frame you need about 40x magnification.
So doing the math we find the following FL needed by sensor size for 40x magnification:
Full Frame - 1720mm
APS-C ------ 1100mm (BTW a 500mm on a APS-C sensor gives you about 18x mag.)
4/3 ----------- 864mm
1" ------------- 635mm
1/1.7 (Q7) -- 380mm
1/2/3 (Q) ---- 306mm
I think the implications of these numbers are obvious - except for the Q sensors getting the magnification needed for most birds, is impractical for most of us on this forum - Too big, too heavy and too expensive. In a word - impractical.
Final conclusion - there is no free lunch when it comes to bird photography.
BTW go here (on this forum) if you want to see my bird pics taken with a Q-S1 and a 560mm scope at 60x magnification (over-kill but it's all I got right now) ......
https://www.pentaxforums.com/forums/122-lens-clubs/55946-300mm-plus-lens-club...ml#post3307819
