Magnification of different lenses at 8 feet.
(Or it's hot, how can I feel like I'm doing something without actually moving.)
Magification is the size an object in real life, compared to the size it is on the sensor. SO a 1:1 macro, a small fly will be exactly the same size on the sensor as it is in real life. Of course when you blow the sensor image up to 11x14 for your screen it will by hundreds of times life size, but, that's the standard.
If magnification was 1:6, the image would be 1/6th life size etc.
A 135 mm lens is 135 mm at infinity, that's how they are measured. So if it's a simple lens the light coming into the lens, the photons will be functionally parallel. That's what infinity means optically. With a simple 135 mm lens, the light will focus, 135mm from the optical centre of the lens. As you ficus a simple lens, if the focal plane is constant, you have to move closer to the subject, to maintain the subject in focus, with a simple lens, to keep the subject in focus therefore, you are functionally enlarging it.
With my 70-210 as I focus, the front element moves closer to the subject, and the effect of that is more magnification. With my 60-250, the front element remains in the same place and internal elements move, meaning there is not as much magnification even though they would create the same result at infinity. Since almost all lenses have more than one piece of glass in them, some having 8 to 13 elements as part of their CA correction design, each lens focusses to different levels of magnification at different distances from the subject, except for focussed on something at infinity, which should produce the same result.
OK here I've run a brief test for you, to show the new glass old glass thing.
The oldest.... all taken 8 feet from the ruler from the same tripod position.
Vivitar M-135... showing 17 real inches of image.
F 70-210, set to 135mm shows 17 inches of real image
The DA* 60-250 @ 250 mm shows 13.5 inches of real image.
The DA* 18-135mm shows 21 inches of real image
The DA* 60-250 shows @ 135mm shows 20.5 inches of real image.
Hence at 8 feet, I'm getting less magnification from my 60-250 at 135.. than I did with my Vivitar 135 or F 70-210 at 135mm. And the DA 18-135 is like a half inch better than the 60-250 both at 135mm.
Want more magnification from your DA*60-250, you have to use the HD DA 1.4 TC which gives you 350mm and 10 real inches, and in all fairness, the 1.4 works well with the 60-250, purples fringing becomes an issue on the 18-135 and Vivitar 135 and F 70-210, , and probably will with any lens that extends it's front element when focusing. so a TC not really an options on those lenses
Or really want to crank it up use the DA*60-250 and F 1.7 x AF converter at 425mm... 8 inches...
Of course, the most magnification close in is going to be my A-400 first by itself at 5 inches...
And then with the 1.4 TC at 3.5.
But for some real magnification you want something like this...SIgma 70 with the HD DA 1.4 TC walked right in to the 1:1 setting - 16mm on a 22mm sensor..
That's about .4 better than 1:1. The DoF is so narrow, the ruler goes out of focus where the blade is slightly sloped.
As general observation based on my own shooting practice, if you are shooting small birds and animals close to you, use older glass, or, a TC on your newer glass. At least with my images, older glass equals more magnification close up, newer glass equals reduce magnification. If you are used to an F 70-210 you're going to be disappointed with the magnification of your new 60-250. The 70-210 is more magnification at 8 feet, than the 60-250.
