Originally posted by transam879 Just wanted to put out here that my AF motor on my DA* 300 (I'm guessing) got stuck. Thought it was a dead motor. I couldn't AF or MF as even turning the focus ring didn't work. I took a screwdriver and turned the screwdrive mechanism on the lens mount (can't remember if it was clockwise or counterclockwise) a couple times and the AF and MF has been working on the lens ever since. I delayed posting this just to make sure it continued to work, which it has. I apologize if this has been posted already but couldn't find anything on here or the Internet that addressed this other than partially disassembling the lens mount, something I preferred not to do. Just wanted to post it in case someone had a similar issue.
I wanted to start this discussion back up if possible. My 50-135 was Stuck, SDM and MF would NOT work. I attached to a screwdrive Film body and the focusing started working. After playing with it a little, I then put it back on my K-5iis, It was still stuck both SDM and MF. I kept spinning MF and hitting SDM and finally it started working.
Is this the Motor or something else "broken" in the lens?
