Originally posted by Dice I had both. If you need 2.8 throughout and WR in a wide/normal zoom then keep your 16-50. There is no other f2.8 lens in a WR design that is smaller. But if you don't mind the short range and the thought of a variable lens then the 20-40 is a nice compact package. Speaking from my experience, the 20-40 does deliver prime-like images and the build quality is very similar to the DA ltds. I don't find the limited range and variable aperture ever an issue. But I can see where others would. Small lens hood okay but flare is so well controlled and for 2.50 I could get a rubber hood but I don't even think about it. AW vs. WR not sure I have an opinion and neither has been a problem for me but in super harsh weather I could see where the WR might be better. Both of these lenses are widely criticized... mostly by those who don't have them.
I also have both, and they are both great lenses. 16mm is nice for some shots (architecture, landscape), but the small size and beauty of the limited, along with its clarity, make my K5 + limited combination almost as compact as a mirrorless system (but with better photos).
