Originally posted by Ratcheteer NEVER EVER USE GLUE - the vapor will find its way inside the lens and cause yellowing
Typical super glue (I use the thick gel type) will not as long as it is well-ventilated while it dries. (Once dry it is perfectly fine, even on internal parts.) And it wouldn't be yellowing, but a fogging. Gluing the pin down on most lenses works fine and is usually reversible with a drop of acetone. (But I wouldn't glue it if you ever thought you were gonna reverse it as acetone will melt some plastic surfaces so you must be careful.) I've glued lots of them -- cheap lenses that I'm going to keep forever or that have mounts that are difficult or just not worth bothering with opening up and trying to stick sleeves on, etc. There seems to be a paranoia about using glue but if it is ok with you glue is quick (to apply, you must wait for it to dry) and easy and isn't going to harm the lens. Anything involving removing the mount or bending things is actually more risky and easier to bungle.
Certain lenses ARE super easy to alter the mount, so usually it is just a matter of checking Google. But others are very difficult to get the mount off or do anything internally, personally I just glue it and be done with it. Never had a problem, I use those lenses often.
Another word about "reversible" -- even if it is easy to undo what you did, if you have a pin that has been held down for months or years, don't expect it to work just as good as new when you finally release it. These are decades old lenses -- the spring will lose tension. These should be considered permanent alterations. If you want to use the thing on an old m42 camera body with the auto-aperture function intact, then don't alter it, simple as that. If you're going to mod it, just leave it modded, even if you sell it later -- most buyers will want it that way anyway and the ones that don't won't want one that was artificially pinned down for who knows how long and later "reversed"...
