Originally posted by PaPa Could someone please interpret what Driline was trying to say by his comment "Putting that expensive teleconverter on that zoom lens is like putting Michelin tires on a Yugo".
Just in case you are serious: The 18-250 is a fine lens for what it is, a slow consumer super-zoom. It is not, most definitely, a lens most would use a TC on. The HD 1.4x RC is a professional level teleconverter designed to be used with high end glass such as the DA*300, the DFA 150-450, the DFA*70-200 or other high quality lenses. So while Driline's comment may have been a bit of an exaggeration (hence his use of the smiley) there is a lot of truth to it.
There is no reason you cannot use the TC on the 18-250 if you are happy with the results. Just like there is no reason you cannot put Michelin tires on a Yugo. They will both work just fine, you just will not be getting the most out of the TC or the tires.
Hope that explanation helps, it is not my intention to get involved in this particular spat and if you were only trying to prolong the argument instead of looking for a serious answer then my apologies for being gullible.
