I own a Zenitar 16/2.8 Fisheye (a 180 degree fisheye on FF 35mm) as a general-purpose ultrawide and while I have the means to correct in PP, I very seldom do so. The methods to de-fish fall into two main categories, those that sacrifice a large portion of the image resulting in modestly wide final image and those that replicate and/or remove pixels to normalize the view at the expense of detail.
Below is a link to photos from my Flickr stream taken with the Zenitar. Most were done on APS-C and the rest on 35mm film. Only one was corrected in PP. I have found that for landscape work, the eye is remarkably insensitive to a bent line. That may be because the eye itself is not a rectilinear lens. What's more, a fisheye does not distort or "smear" proportions at the edges. As a result, some subjects appear more natural even if a little bent*
https://www.flickr.com/search/?user_id=28796087%40N02&sort=date-taken-desc&t...tar&view_all=1
For those who prefer to not click through:
Here is a framing that would be impossible with the subject and a rectilinear projection...
Here is a fairly conventional landscape...
A little architectural work. This one would defish with little loss and with quality comparable to a properly "corrected" image from more expensive rectilinear lenses at similar focal length and field of view.
And just to prove that the Zenitar truly is a fisheye.
* Fishiness is related to the position of the lens axis relative to the straight lines within the frame. For many subjects there is no discernible bending at all.
