Originally posted by Nicolas06 If lot of demultiplication is applied and the focus group is light enough, the focus will be faster, but less precise.
Stepping motors...they use stepping motors. Even the so-called wave motors actuate in discrete steps. Translation? They don't overrun. The base precision is based on the size of the steps. AF detection precision is related to the prism angles and number of photo-cells for each point in the detector.
Originally posted by Nicolas06 Modern in lens focus design are more than just a motor inside the lens. Feedback loop mechanism with sensors inside the lens allows to check how the lens process the camera order and fine tune acceleration/decelaration and greatly reduce the risk of front/back focus and increase precision. Smaller focus group allow for smaller motor that can then be more reactive and work better with contrast AF.
Much of the above is quite true, though I do believe you are overthinking some of it. My understanding is the body gives the lens a rough notion of direction and movement. And while the in-lens motor is controlled by the lens, the feedback loop to attain focus is back through the body. The lens moves, the body reacts. In order for the body to give specific instructions as to movement, it would need to have intimate knowledge to map its focus histogram to lens movement parameters for the current focal length. I am not saying this is not how it works, but it would be nice to have a reference. Link?
As for front/back focus, it is my understanding that is related to the optical quirks of a particular lens and not its drive mechanism. After all, manual focus with the same lens requires the same fine adjustments. Drive precision may affect far-near vs. near-far front/back focus, but that is not the common cause. When such exists, an intermediate adjustment is used.
Originally posted by Nicolas06 There a nice article on lens rental on the evolution of the evolution of AF. Basically before the best lenses AF bundled with PDAF where fast but less precise than MF or LV AF. Now they are both fast and precise and lenses made for contrast AF are no longer slow to focus. This is both software and hardware related.
I, for one, would appreciate a link to this article. I did several searches at LensRentals and came up with nothing. The idea of lenses being designed for CDAF as opposed to PDAF is new to me.
Sorry for being so contrary, but you really tossed a lot of stuff out there.
Originally posted by Nicolas06 Myself I have nothing against screw drive and don't care of the noise on the ltd.
I guess not, if your signature is up-to-date
All of those lenses are screw drive and the DA 15 is a bit of a speed demon. At least that is my memory from when I demo'ed that lens. I think we may have chased the OP away with all the talk. If so, that is a shame.
My advice has been and continues to be to buy for the optical qualities unless one has a high priority for quiet operation or speed. If one needs speed, then actual comparison testing with the intended body might be in order. Many (most) motor-in-lens lenses are not that quick and those are not limited to Pentax-brand. Likewise, not all bodies are created equal in their ability to drive the lens.
