Originally posted by Fat Albert Has anybody done this?
Mostly Canon FF shooters.
Originally posted by dcshooter The biggest pro is IMO real time metering if you are going to be shooting in a scene with a lot of lighting changes, plus realtime view of the actual DOF.
The biggest negative is loss of the automatic diaphragm actuation. Real time metering is highly overrated and the rapidly changing light scenario relatively rare*, IMHO. Meter once and shoot away until the lighting itself changes. Compare these flows:
Manual/Preset diaphragm, emasculated K-mount and M42 (Av mode):- Manually open aperture
- Frame and focus
- Manually stop down aperture to desired DOF or shutter speed
- Make exposure
- Repeat sequence
Auto diaphragm actuation, K-mount (M mode):- Select aperture using aperture ring
- Press green button
- Frame, focus, exposure
- Repeat last step
The second flow is analogous to how things work with stop-down meter cameras such as the Spotmatic. Automatic diaphragm actuation is a huge advantage. Without such, SLR shooting for many subjects is sort of a
joke and often enough the saddest part is that the photographer will often forget to do that manual stop-down and/or miss the shot as a result.
For example...Below is a photo taken with a Pentax SV in a difficult lighting situation. The exposure settings were based on an incident reading from a hand-held meter with the Timberline Lodge in Oregon as the subject. I was walking around to the back side of the building looking for interesting angles when I saw a snowboarder coming rapidly down the trail to my left. All I had to do was bring camera to eye, focus, and take the shot. If the M/A switch had been on the "M" side, I would have missed either focus or the action.
For those that are interested, the exposure settings were originally used for the photo linked below:
https://flic.kr/p/88FYwm
* The most common error is to mistake light vs. dark subjects as requiring different exposure even though both have the same illumination.
