Originally posted by Fat Albert The implication is that this is a destructive, irreversible process. Can't one just unscrew the lever?
well. I find this thread after I have been playing with my M42 lenses and thinking of using the K ones the same way. Curious about other experiences, so I revive the thread...
I have unscrew a bit of a cheap K lens and the non destructive lever removal or neutralization isn't trivial in this case. This may be common to many lenses...
the lever here is a part of a thick ring inserted on a ballbearing inside the K mount. So there's no unscrewing possible, if it is to removed, it must be cut off:
the ring on ballbearing has a longer lever inside the lens, that does release the diaphragm, and a spring keeps it full open otherwise (when the camera doesn't trigger the lever):
the notch inside the lens, where the internal lever releases/keep the diaphgram aperture:
as I see it, the lever can be neutralized by unscrewing the spring on the internal side of the mount (the spring holding the internal ring of the mount) but the long internal lever must be kept in order to keep a functional aperture ring. That's were it's not trivial...
I think I will just screw everything back on and let it like that. When I took the mount off, I wasn't careful enough, the aperture ring came off also and the small ballbearing doing the clicking stops jumped out somewhere. I had some old olympus lens around, that I have destroyed in order to extract ballbearings and springs; I started with screws but at a certain point had to use a hammer, well...
