Originally posted by csa I currently have the Tokina 400mm AT-X SD f.5.6; which I'm very pleased with the image results. However, it is rather handicapping, with the fixed lens, that I have to move back, etc., to get a different view, or to even get the entire subject in the image, which sometimes results in the subject being frightened away.
I'm wondering about the quality (sharpness, etc.) between my lens and these:
Sigma 120-400 F4.5-5.6 DG APO OS HSM
Tokina AT-X 80-400 F4.5-5.6 ver. II
Thanks in advance for any opinions!
I am not familiar with the Tokina AT-X 400/5.6, but I am very familiar with the Tokina AT-X 80-400/4.5-5.6 AF-II. As much as I dearly LOVE my AT-X 80-400/4.5-5.6 AF-II, I would have to point out that it less sharp and less contrasty at 400mm than at other FL's (of course, for many long zooms, being softer at their longest FL is pretty common). Therefore, I think you'd likely be disappointed in IQ at the one FL that you are used to using currently -- after all, that 400/5.6 is optimized for 400mm, while the 80-400 (and the AF-II version is only marginally better than the 1st version) has to be quite a compromised optical design in comparison.
EDIT: To illustrate the above, I offer this: When I'm "out and about" and wanting to be ready for most any telephoto situation, I might take the 80-400. However, when I know I'm going to mostly want a longer FL (say, for birding), I take the F* 300/4.5. Not surprisingly, the F* is sharper than the 80-400 is at 300mm, but crops of the F* at 300mm are also sharper than those of the 80-400 at 400mm, as well.
