Originally posted by audiobomber I disagree. I can't see any justification for what you're saying. When the shape of the image and the shape and length of the hood match, you will have perfect coverage. The image you showed is a rectangle, not a petal. If you create a perfect rectangle shape for a FFL lens, and add some material in the center to make it a petal, it will create a shadow.
What image are you looking at?
Oh I see what you saw. The orange part is the part that is the hood. The white is showing the light that makes it to the surface of the sensor. Look at the top and sides and see that the corners are where the hood is at the shortest. If you then cut the hood off to that size there would be sizable leaks of light. And yes if the hood were wider (rectangle) then perhaps this would be less of an issue. I think it is very difficult to judge these fully without math and specific lenses.
---------- Post added 08-17-15 at 09:32 PM ----------
Originally posted by Digitalis In defense of rectangular lens hoods, I have had issues with petal lens hoods, with stray light leaking in through the gaps plenty of times - this would not have happened at all with a rectangular or Bucket lens hood. Though I view bucket lens hoods as being the least effective design and the most likely to contribute to vignetting. The main drawback of Rectangular lens hoods is that isn't possible to reverse them on the lens for storage.
I would argue that any hood can be too short for conditions. There is a limit to practical design. If you had two hoods one petal and one rectangle with the distance from the front element the same and the width the same overall then the petal wins. A rectangle due to the width can be wider and perhaps then longer so that it doesn't interfere. I think both shapes work well. The truth is there are no perfect hoods.
Just a final thought - I can absolutely see that a longer wide rectangular hood could be designed to intersect that light pattern farther out. It would be larger and bulkier but could have better coverage than what I was visualizing. But at the same time - the petal would be smaller and lighter for similar coverage.
I have that hood you have there or more accurately a JJC reproduction of it - it is a pain when fitted backwards but it can be done - just awkward.
