Originally posted by Digitalis I could see the issue straight away...get that lens replaced. It is apparent that there is some degree of optical misalignment causing the blur in the upper left corner, at f/7.1 DOF should be adequate for that subjectdistance, at and 1/250th the chance for camera shake affecting the image is significantly reduced.
^^^this
shooting a chart means that you must have the sensor perfectly square to the chart, which is a pain in the neck... even outside with wind at 1/250th, both sides should look similar, but it's usually best to shoot it with a fast shutter.
o.p. did a decent job with the subject matter, but next time post a full-size image, not something that has been edited... lenses can have out of focus areas, and wavy field curvature problems, that don't show up with partial crop posts.
i would return this lens for refund or replacement, if at all possible, don't hassle with sending it to the manufacturer unless there is no other choice.
