Veteran Member Join Date: Feb 2012 Location: Slovenia, probably |
DA pros: - Newer coatings
- short focus throw, means AF can move faster (probably)
- rounded aperture blades
- light, small
- made of plastic (this one could be listed as pro or con. Plastic used to be treated as dirt, but these days plastics are fairly tough and can allow a lens to "bounce", instead of bending if it were made of metal. Its a thing of taste, some prefer metal, others prefer plastic - and seems plastic is the future)
FA pros: - aperture ring (might be required if you want to shoot on older film SLR or use certain macro tubes or bellows, lens reversals)
- slightly longer focus throw (probably. Maybe someone measured? Still not as long as older, fully manual lenses)
- heavier, sturdier build
- distance scales (DoF scales? or are DoF only on even older models?)
I think all 50mm f1.7 since M series up to DA 50mm f1.8 use basically the same optical formula. Now, of course there were changes in the manufacturing process (factories moved, new employees), materials (material regulations change, new materials are invented, etc.), and possibly even small changes in the optical formula itself (some elements curved differently, closer or farther apart, but we don't really know - those lens diagrams we see are only for marketing purposes, not actually perfectly accurate representations, not technical drawings). Its a good optical design, makes a very compact, but still bright and sharp 50mm lens (might be a smidge over 50mm, actually)
Anyway, get the DA 50mm f1.8 for a fast, good quality, light, affordable, great IQ lens with full automation on modern SLRs. Get FA or F 50mm if you want AF and slightly more solid barrel, aperture ring. Get A for even tougher build, lens made to last, with auto aperture, but MF. Get M series if you want manual, affordable, but all metal and still great image quality. If you put these lenses side to side, I doubt you would notice much difference. Main differences are that newer lenses have better flare resistance (though, with a lens hood, older 50mm won't have a big problem with this, either), maybe better contrasts. And the DA 50mm has rounded aperture blades, so its bokeh might be more round (but gives fewer starbursts on point light sources).
When I was looking for a Pentax 50mm, the DA wasn't out yet and a new FA was oddly expensive in this part of EU. So I got a M 50mm, and it serves me well enough. Today, I might think about getting a DA instead, since you can find it for really low prices and get full automation.
