Originally posted by stevebrot I just mounted my Adaptall-2 M42 adapter (sans lens) to my K-3 and can confirm that the pin on that mount (8mm from mount face) overlaps the power zoom pins by at least 1mm and ever so slightly contacts both pins as it passes by. It makes a slight clicking sound. I will try and get a photo with my phone cam to post.
Yes, your picture demonstrates it perfectly. I also get the faint clicking sound with a couple of lenses. In fact, when I initially fitted the Jupiter 21M, it got stuck until I gently moved it back and forth to release it, and I now wonder if that was as a result of the sharp, flat-ended stop down pin fouling the SDM contacts.
Originally posted by stevebrot The Kipon-type would be nice, though they are notoriously hard to find. I would also wonder how deep the Kipon lip extends and whether it has potential to run afoul of the contacts as well.
OK, so I had a look to see if the Kipon adapter touches the SDM contacts, and it does (see first pic below). However, while I can't be 100% sure of this, it appears that the part that is touching the contacts is a chamfer (second pic). Regardless, there is *much* less risk of damage to the contacts from this smooth ring as opposed to the sharp edge of the stop down pin.
My Jupiter 21M and Helios 44M seem to have the poorest finish on the stop down pins. By contrast, the pin on my old Sun Systemat 35mm has a very smooth, rounded end, much like the SDM contacts themselves, so that is less likely to scratch / gouge as it passes over them.
Originally posted by stevebrot I will see what I can do to write up a fresh thread as the basis for a potential sticky.
Great
I think this is essential knowledge for anyone experimenting with M42 lenses. The potential for damaging both camera and lens is clearly there. Let me know if I can help?
