06-18-2008, 12:36 PM   #1
Lens cap for DA 35mm/2.8 macro
Love almost everything about the 35mm macro limited except the lens cap. It's a nice metal and felt cap but it likes to fall off a bit to easy. I'm looking for a standard clip on plastic lens cap. The problem is that the standard 49mm cap doesn't work unless there's a filter on the lens. Does a 52mm cap work?
Alan
06-18-2008, 12:51 PM   #2
49mm cap worksish
I have the opposite problem; I like the felt lined lens cap but I went and left it in the middle of a rainforest doing fieldwork...doh!
I'm currently using a 49mm cheap jessops clip on cap. It works but is a little bit awkward. It actually stays on better than with my 50mm where it had the tendancy to pop off. I don't use filters on either of these lenses.
I've got to get round to getting one of the old asahi metal push on caps which are apparantly good.
06-18-2008, 01:03 PM   #3
QuoteOriginally posted by pentaxkat Quote
My standard pentax 49mm cap doesn't work. Not even close. Perhaps there's different designs out there but I haven't had any luck with mine.
Alan
06-18-2008, 06:10 PM   #4
if the cap is like that on my FA77, i bought a cheap filter, remove the glass, screw on the filter ring, then use a clip on cap. that doesn't work for the DA21 though...
06-18-2008, 11:12 PM   #5
QuoteOriginally posted by k100d Quote
That's a very good idea. It should work fine as the 49mm cap works on the 35mm macro with a filter. I have a few cheap ones around.
Thanks
Alan
cap, cap for da, k-mount, lens, lens cap, macro, pentax lens, slr lens
DA 35mm lens cap replacement samski_1 Pentax SLR Lens Discussion 5 10-21-2016 07:24 PM
35mm 2.8 macro lens cap + filter? patrickw Pentax SLR Lens Discussion 7 01-07-2010 05:19 PM
Lost lens cap on 18-55mm DA L. Can anyone confirm if this eBay cap is the correct one philthy Pentax SLR Lens Discussion 3 10-15-2009 01:26 AM
All times are GMT -7. The time now is 10:51 AM. | See also: NikonForums.com, part of our network of photo forums!
