Originally posted by hjoseph7 I'm not a glass-worker and don't know much about the lens making process, but I often wondered what makes certain lenses produce more contrast than others ? If I compare all of my lenses, some produce better colors and/or better contrast than others. For example I just started testing my Takumar 35mm f3.5 which arrived in the mail a few days ago. This lens produces extremely saturated colors especially the red, brown and greens. Perfect for landscapes I would say, but how did the folks at Pentax arrive at this formula ?
Is it the lens coatings, maybe but even some older lenses with single coatings can produce very colorful images. I don't mean to sound stupid, but when I look through the lens everything looks clear to me.
Once I read a review on a lens, I forget which one and the reviewer claimed that Pentax purposely oversaturates the image on their cameras to produce brighter, more saturated pictures. if this is true then that would mean that they manipulate the sensor, but that still does not answer the question of why some lenses produce more contrast than others ?
Lens designers have two ways to make the contrast higher - increase the transmittance and decrease the number of interfaces between air and the lenses. Many of the pentax primes have very few elements and they historically had good coatings that transmitted a lot of light.
Let's say that 99.7% of the light passes through each lens. If you have 5 lenses with air-glass interfaces, then total transmitted light is 99%, then 0.99^5 = 95.1%. If you have 10 interfaces it is already 90.4%, and many zoom lenses have more. So fewer elements is better for contrast. If you have better coatings, you could lose less light at each interface and for 99.5% transmission and 5 elements 0.995^5 = 97.5%, and for 10 of them = 95.1%. The best lenses these days have 99.7-99.8% transmission for each lens, and it varies a little for different colors. See Fa 43mm for an example:
Pentax smc FA 43 mm f/1.9 Limited review - Ghosting, flares and transmission - LensTip.com
Now look at the block diagram of the 35 F3.5 Tak:
https://www.pentaxforums.com/lensreviews/data/20/Super-Multi-Coated_TAKUMAR_35_3_5_optics.jpg
And compare that to a zoom lens:
SMC Pentax-FA* 28-70mm F2.8 AL Reviews - FA Zoom Lenses - Pentax Lens Reviews & Lens Database
Even with poorer old coatings, takumar has much easier job to do with just a few glass pieces in there.
I hope this makes sense, cheers.
