06-19-2008, 03:44 PM   #1
is my copy ok or??? 16-45's 45 mm vs 50-135 mm' s 50 mm
my 16-45 with k10d has backfocus problem before i sent it to calibration. i checked it s focus accuracy using the focus chart and i am sure it is ok.
but i am not sure whether its a good copy or not. i looked at photozone.de and compare its sharpness with 50-135. at center, their sharpness very close when 16-45 is at 45 mm f 5.6 and 50-135 is at 50 mm f/4. i attach here two comparisions;
first one is to compare the different aperture results of 16-45 (4 and 5.6)
second one is the comparision of 50-135 (50 mm f 4) and 16-45 (45 mm 5.6).
do you think my copy is ok or???
btw i used tripod and mirror lock.
many thanks
halil
06-19-2008, 03:54 PM   #2
Pretty small images to tell.
Make some prints
Thats what i do to check quality
Dave
06-19-2008, 03:54 PM   #3
hll
i am sending the second comparison again...
06-19-2008, 04:16 PM   #4
hll
45 mm 5.6
http://www.flickr.com/photos/80022800@N00/2594115506/sizes/o/in/photostream/
50 mm 4
http://www.flickr.com/photos/80022800@N00/2593275665/sizes/o/in/photostream/
06-19-2008, 04:50 PM   #5
Nesster's Avatar
your flickr pages are private, can't see them.
Seems your copy is like mine, of the 16-45 - there's good contrast that when not compared and pixel peeped looks great - sharp, saturated - but when compared to something with greater resolution it turns out not to be as great as first seems.
This doesn't make it a bad lens. After all, one hopes to be making photographs rather than comparisons.
I think your lens works fine. I don't see that your other lens resolves much more, it may have less contrast however. With two identical shots, which one comes out to a bigger jpeg?
ps. if you want to see my comparisons, vs. prime lenses: lens_testing Photo Gallery by jussi at pbase.com
in each case, on its own, the 16-45 looks good, imho. Only when comparing details with other lenses does it seem to suffer a bit.
06-19-2008, 05:10 PM   #6
hll
i aggree with you and i am glad you think it is fine copy.
btw,i have never been succesful uploading picture in their original sizes...
halil
06-20-2008, 09:03 AM   #7
alohadave's Avatar
QuoteOriginally posted by hll Quote
halil
When you are a non-Pro member at Flickr you don't have access to the full size of the picture. It's still there, you just can't get to it.
copy, focus, k-mount, mm, pentax lens, sharpness, slr lens
Copy cats Naturenut General Talk 16 09-13-2010 05:32 AM
What do you think about this copy of the DA15mm? TKH Pentax SLR Lens Discussion 43 07-10-2010 02:35 PM
Is my 50-135 F2.8 a bad copy, With photo samples m42geo Pentax SLR Lens Discussion 39 06-19-2009 01:49 PM
What do you think of this 16-50 copy qksilver Pentax SLR Lens Discussion 15 05-26-2008 01:11 PM
On vergeo or ordering DA*50-135 - anyone get a 'bad' copy of this lens? 123K10D Pentax SLR Lens Discussion 0 11-27-2007 05:00 PM
All times are GMT -7. The time now is 01:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
