09-09-2015, 05:32 AM   #31
WPRESTO's Avatar
That is highly unlikely and unnecessarily complex to implement. The most sensible and easiest to implement would be what Sony does in its A7 line which is to have three options: Auto, FF, Crop. That way the user can use a crop lens even when it vignettes. I get wonderful 8mm wide pictures with my Sigma 8-16 by by selecting FF and just cropping out the black in PP. Or can can just let the camera do the cropping for somewhat reduced coverage. Pentax would be crazy to lock out all the FF compatible DA lenses it already has. Might be the killer for me.
I was thinking of the menu options for format as overriding any automatic cropping. Of course to make it work properly, and add complexity and expense, you would need either 1) an EVF rather than a mirror; or 2) frame lines superimposed like composition grids so you could see the format selected. I would guess the latter will included in the new FF Pentax for dealing with APS-C only lenses.
09-09-2015, 12:04 PM   #32
Mikesul's Avatar
With many DA lenses the camera would need to do nothing since they cover the FF circle just fine: such as the DA70, DFA100, DA+55 and Da*300. Pentax just needs to avoid automatic crop of APS-C. It is my understanding that even the OVF FF cameras from CANIKON have a crop mode for crop lenses so Pentax can do that also but it must not be exclusively automatic. Sony is EVF of course but it is easy to use their crop lenses as either crop or in FF mode. Many of those crop lenses become almost FF when the baffle is removed. I can also use my FE70-200 which is a FF lens in crop mode for greater reach. Pentax should be no less flexible.
k-mount, pentax lens, slr lens
"55-300 on 300/f8" vs "60-250 on 250/f5.6" snimcho Pentax SLR Lens Discussion 35 06-25-2015 01:33 AM
Normal or not? Focus ring on quickshift lens occasionally "sticks" (HD DA 55-300mm) Doundounba Pentax SLR Lens Discussion 11 04-18-2015 01:45 AM
which is better "DA 21MM F3.2AL Limited" or "SMCP-FA 20-35MM F4" ? Flame Angel Pentax SLR Lens Discussion 9 07-04-2013 08:10 AM
Which "conformist" FAST lens would you like Pentax to have? RolloR Pentax News and Rumors 57 12-15-2010 02:06 AM
DA 35 Macro vs. FA 35 "normal" Vern Pentax SLR Lens Discussion 20 02-28-2009 03:41 PM
All times are GMT -7. The time now is 02:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
