Originally posted by rboe For years conventional wisdom said that for best results; use primes. For me, the 60-250mm has been a huge disappointment in that regard as I tend to use it 90% of the time as a 250mm prime. At agility trials I do get the opportunity to use the shorter focal lengths and as long as I do my part to get a proper shutter speed to freeze the action it is quite sharp. I do prefer my 300mm telephoto, but with dog trials, the 300 can be too long too often.
I did have to adjust the focus of one lens in the camera; but I can't recall if it was the 60-250 or a different one - I suspect it was the zoom.
I have the 50-135mm and the 60-250mm has pretty much made the 50-135 the best lens I don't use now. There are a few times where I need/want 50mm, the F2.8, the lighter weight etc. so I do use the 50-135, but the 60-260 pretty much kicks its' butt.
Well if you really use it at a prime, maybe you should have considered a DA*300. But even a prime will not be perfect.
More to that, th performance of most long tele, prime or not will not match the performance you can get in more common range. Pass 200mm there more compromize in the design to mitigate price and weight/size.
maybe the 150-450 perform better at 250mm but that twice the price here and twice the weight. And likely the DA*300 is bit better at f/4, but you loose the zoom capability then...
And remember the 10% case maybe justified completely the zoom case as you didn't want to buy and put in the bad both zoom and prime.
Anyway, I don't think that a non defective 60-250 would show any issue even at f/4 if you don't crop significantly you shoot or look at 100%. Maybe it's not perfect, but is sure good enough for a 250mm framing... Maybe not if you try to crop to a 400-500mm framing through.
