09-10-2015, 11:05 PM   #1
Pentax K 105mm 2.8 replacement hood?
I came across a K105mm this past week and I decided I need a hood. Which hood (besides the original which I cannot find) is what I'm asking for. Based on your experiences with this focal length what should I do? I'm tempted to buy a step up ring and just purchase a Takumar 105 hood.
09-11-2015, 08:50 AM   #2
so... as near as I can tell you need a ph-r52 lens hood (original oem hood)
VG Asahi Pentax 52mm Standard Lens Hood FOR 50mm F 1 2 F 1 4 55mm F 1 8 J38 | eBay
is the correct item I believe - the same hood was used for the K50 f1.2 as the K105 f2.8
sorry it's rather pricey....
09-11-2015, 12:30 PM   #3
robry's Avatar
I am using the Nikon HS-4 hood for this lens. It is a little bit longer and works better than the original one which I also have. Easier to find too.
Cheers Robert
105mm 2.8 replacement, hood, k-mount, pentax k 105mm, pentax lens, slr lens
Replacement Hood for Adaptall SP 80-200mm f/2.8 (30A) minahasa Pentax SLR Lens Discussion 3 08-15-2013 04:19 PM
Sigma 28-105mm 1:2.8-4 lens hood jolepp Pentax SLR Lens Discussion 7 02-19-2011 02:13 PM
Takumar SMC 105mm 2.8 lens hood question. pickles Pentax SLR Lens Discussion 2 06-05-2010 02:38 AM
All times are GMT -7. The time now is 02:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
