Few months ago I borrowed the HD 1.4 teleconverter for a couple of days and briefly tested the coverage on Sony A7R.
Didn't try the DA* 70 but it fully covers FF without the TC , so I guess it will work with the tc as well.
From what I remember:
DA* 50-135 + HD 1.4x fully covered FF trough the whole range (and I did not pixelpeep too much since I just wanted to check the coverage/vingeting, but picture quality seemed pretty good)
DA* 60-250 + HD 1.4x - was actually worse, darker corners than using the lens alone. Strange, since when used with no teleconverter it has much better FF coverage than 50-135. I've noticed the 60-250 has a baffe on the back side which might be causing the vingeting/dark corners (on FF), so maybe if removed it will completely cover FF.
I've tested few others that I had with me as well but I don't remember the details anymore, except that the 35 ltd macro looked very good, athough I guess it makes little sense to use it that way.
