Originally posted by LittleSwans I want to get a macro lens and was told that the 100mm is really useless indoors. So the other option is the D FA 50mm f2.8 Macro. How does this compare to the FA 50mm f1.4 which I currently own in terms of quality and sharpness?
<heretic alert>
Have you thought about getting a set of extension tubes instead of a new lens?
</heretic alert>
Seriously though, with the APS-C digital format, I think you will find that a 50mm macro is a more useful length than a 100mm macro.
Something to consider:
Quality and sharpness concerns are moot, the macro lens can do macro photography, the FA 50/1.4 can't (unless you go for the aforementioned tubes, and then you have compromised it's optical quality somewhat). If you choose to buy the 50 Macro, treat them as two separate entities, if the macro turns out to replace the 50/1.4 in your photography, then make the choice to sell it or keep it. My guess is that you will end up keeping both, as they are very different lenses.
The advice regarding the 35m Macro is good as well, though personally, I would be holding out for the 30mm lens that is due out at some point, or else getting a 31mm LTD in that focal length range. This is because I have never had much use for a standard focal length macro, but have always had a use for a short telephoto macro.
Conversely, I use lenses close to standard focal lengths for most of my non macro photography. The lenses on my camera most of the time is the FA31mm or FA35mm.
I have both 50mm macro and 100mm macro lenses, and when shooting film, I rarely used the 50mm lens, but used the 100mm lens extensively. Most of my macro work benefits from a longer working distance, making the longer lens preferable. When I made the adjustment to digital, I found that my shooting needs didn't change, though my focal length needs did. The 50mm macro became useful, the 100mm macro became more useful in some ways, less in others, and the 200mm macro became rather more limited in scope, but just the thing for candid photos of butterflies and the like.
At the same time, I still don't see any need in my own work for a standard macro lens, but I see a real benefit in my work for a fast standard lens. I am hoping that the 30mm turns out to be an f/1.4. If it is, and it's a good enough lens, it could replace my 31mm as my go to lens.
Sorry for the digression.....
