Originally posted by Iberia Hi,
I have bought a Pentax-A 2.8/28mm: the glass is clean, as are the blades and the focus ring is nicelly stiff but the image quality was a major disappointment.
Center is sharp but corners are soft/fuzzy at all apperture settings wider than f/11...the DA 21mm isn't particularly sharp in the corners either but it's definitelly not as bad.
Could this be a bad copy?
I was planning to get a Pentax-A 50mm next but I now feel like giving up on Pentax-A lenses altoghether.
Cheers,
Ric
The A 28/2.8 is, unfortunately, not exactly a star in the A series lineup -- it is known to be somewhat mediocre (which is NOT to say that it can't make useful images). Furthermore, I would definitely not judge an entire line from any one lens (in this case, from one that is not truly representative) -- there are some ~excellent~ A lenses (some carryovers from some M lenses, or even from K lenses), while some were brand new designs.
And, you just ~might~ have a bad copy of a not-so-great-to-start-with lens, one that, by your description, might have decentering issues.
Now, I suppose the next thing you could do is to get an A 50/2 for that "Pentax-A 50mm" you're planning on maybe getting, and then you'll think all A 50's are mediocre, too. [However, I do think the A 50/2 is actually better than the M 50/2, but that's another story.]
As has been suggested, take a look at some reviews --
Pentax A Prime Lenses - Reviews and Specifications - SLR and Interchangeable Lenses - Pentax Lens Reviews & Lens Database
However, I will defend your use of a brick wall for some useful lens testing -- sure, "it's not really photography", but it IS one useful way to quickly learn about SOME features of a particular lens. [However, there has to be a better brick wall to shoot somewhere near you than one with such worn, dull bricks, and with some of the bricks in a different plane than the rest of the bricks.]
