Originally posted by PDL I remember reading about people using rotating polarizing filters in geologic thin section photomicrographic technique, stress analysis engineering (Scientific American cover January 1972) etc. etc..
The Elitist - formerly known as PDL
FYI: Polarized light has been used in petrography for a very long time. Some crystals will scatter or rotate polarized light in a characteristic way that enables identification of tiny mineral pieces in thin sections using a petrographic microscope. The latter is equipped with a calibrated rotating stage for measuring the degrees that polarized light is rotated. There are typically other kinds of filters that can be inserted. Some types of plastic, placed under stress or strain, will bend light that reveals, when viewed through a polarizing filter, the stress/strain lines within the plastic . In one application, a part is first made of such plastic, then forces are applied in the manner that the finished part will experience to determine where that part is most likely to fail, allowing modification of shape to deal optimally with those forces with minimal use of materials. Petrographic microscopes are still routinely used in geology, but I'm not sure about polarizing-under-stress/strain plastics in engineering since the advent of super-sensitive strain gauges and computer modeling.
