Originally posted by kentster I have 2 Tamron Lenses. 1) 18-200mm A14 2) 70-200 F2.8 on a K20D.
I believe both are designed for crop sensor cameras.....so i'm thinking 200mm should be the same on each camera ...correct?
The 70-200 seams to to bring the subject in much closer then the 18-200.
Also - I'm looking to add a wider lens to the collection. Does anyone make a 8 to 17 mm lens that doesn't have the crop factor? Or is that even possible.
As stated by others, a 200mm lens is always a 200mm lens and you
should see no difference between the 18-200 and the 70-200. Except that the Tamron 18-200 is not a 200mm anymore when focused closer than infinity. It's called focus breathing. In fact, the Tamron 18-200, when set at 200mm and focused close, is more like 150mm in actual focal length. See this thread:
Re: Focal length ain't what it used to be.: Micro Four Thirds Talk Forum: Digital Photography Review
There are expensive lenses performing much worse. For example, take the Nikon 70-200/2.8 VR II; when used at 200mm and focused close, its actual focal length becomes 134mm:
70-200mm AF-S VR II Lens Review by Thom Hogan
Cheers!
Abbazz
[EDIT] Sorry for the duplicate, I didn't see Uncle Vanya's post.[/EDIT]
