Originally posted by wgosma Ok then; we have essentially the same configuration (I have original aluminum baffle/tube with the 'lip' virtually entirely removed)....let me see if I can snap a few frames and post.
Thanks/Bill
Hey, that's sounds more convincing!
Maybe you will keep it.....
---------- Post added 05-13-17 at 12:21 AM ----------
Originally posted by mattb123 This was also a KEH repair and when it failed again (8 months or so later) they had me send it in and then said they couldn't fix it. But they did refund my original repair bill which was the right thing to do even if it was disappointing. They offered to send it to Precision and put my refund toward that more expensive repair but I just needed the money or a fixed lens at that point so I took the money.
So besides the repair that didn't last, KEH was great and fair. I'd consider them again in the future for other repairs.
Good luck with yours!
Study this:
SMC Pentax-DA* 60-250mm F4 ED [IF] SDM Serial Numbers - Pentax Serial Number Database - PentaxForums.com
After 2012-2013 they did put a new SDM-gear in that 60-250mm - some of the the old ones "clogged" and crashed.
Study your serial number. After that the problems.disappeared. Search the forum and You will find more on this issue - not only the 60-250mm one - also many other SDM-lenses..
Later repaired or manufactured SDM-lenses do not suffer.from this disease!.
There are some of it here in the Pentax forum - search!
If after 2013 - no problems!
Pity that is. Not all but some Pentax SDM-lenses suffered.
My serial number is on the right side.
So if You buy one, new or old, - ask for the serial number..after studying the link above...
/Gutta
