Originally posted by Kunzite normhead just contradicted himself, first claiming the vignetting is confined to the 150-450, then proving that it's there with the A 400mm, too.
You cannot discuss with such a man.
As per usual, you throw the baby out with the bath water.
But yes, I have to admit. it never occurred to me that I hadn't used the TC with the K-1 I'd only use the K-1 and TC with the Tammy 300 and assumed it worked the same with my other lenses. Sometimes I make a mistake, but I correct them. You make mistakes all the time, and never fess up.
---------- Post added 11-16-16 at 12:09 PM ----------
Originally posted by redpit And also we have tested it with our longer Pentax lenses that are FF (like @GeneV with the DA* 300/4 above) and the DFA 150-450 and it can't provide a usable FF image.
I am so glad I bought my Tammy.
I was just walking along in total oblivion to these issues.
I have to agree dudes, that really sucks.
IN the spirit of not throwing the baby out with the bath water.... I repeat.
Tamron SP AF 300mm ƒ2.8 ED [IF] with F1.7x AF Adapter uncropped. There is a tiny little bit of vignetting top left.
The question here is, my Tamron uses the 1.4 and 1.7 virtually flawlessly on the K-1. Is the design of the DA*300, D FA 150-450 an DA 560 such that it isn't even possible to design a TC for them? Clearly the lens design is a factor here.
After all, the fact that the Pentax engineers say the 1.4 doesn't work, doesn't mean there could be one made that does, the possibility of designing a TC for those lenses isn't addressed.
The 560 and 300 are DA lenses, no reason they should work on FF with a TC, but the 150-450? Wat wid dat?
