Originally posted by dlopez6243 Thank you all for the warm welcome. As far as the lenses that have SDM focusing, I've read that they've been prone to failure, has anyone had any issues with the SDM on the 16-50 and 50-135?
I have the 16-50, 60-250, and the 300. All are SDM and I've never had an issue. I can'tspeak to failure rates, but generally you hear about them when they fail but you don't when they don't. All motors will fail at some frequency and my gut feel is the SDM motors, at least in older versions, were failing at a little higher rate than average but that in later versions it has improved.
As for lenses for landscapes (which is also what I mostly shoot), I have the DA 12-24, 16-50 and 60-250. I'm very happy with all. I just swapped my 50-135, which I really liked BTW, for a DA 20-40. I didn't use the 50-135 much after I got the 60-250 but both are terrific lenses. The 20-40 might replace my 16-50 given I have a wider option. Nothing wrong with the 16-50, also a terrific lens, but the 20-40 is more compact so I can lighten my travel kit a little (I also always throw in a fast 50). For the record, the 16-50 has been my most-used lens, more than the 12-24, so I'm hesitant to part with it, but we'll see.
