Originally posted by naomi.mavro Why would I do that ...
You would do that because you asked for help on this forum. The user was attempting to walk you through a diagnostic flow to determine if the problem is with the PDAF (viewfinder AF), lens AF mechanism, or an optical problem.
Here is how it works:
- Acceptable focus using AF(CDAF) in live view?
- If yes, tuning the PDAF may help.
- If no
- Acceptable manual focus in live view (use magnified live view, see manual)?
- If yes, there may be a mechanical issue with the lens AF linkage
- If no, an optical issue is likely
Either of the last two points will require a service visit. Before fiddling with lens calibration is is best to establish that the lens is capable of sharp results. Manual focus using magnified live view is the gold standard.
