Originally posted by UncleVanya Another option - albeit weird - would be to build a physical interface to the screw drive and read the direction of the drive as it turned and translate that to motion of the focus mechanism. I don't actually know how the mechanism knows when it reaches the end of the available focus range (infinity or MFD) there has to be some feedback.
I thought of using the screwdrive as well.
I wonder if I can get a broken lens...
---------- Post added 20-10-15 at 09:49 ----------
Originally posted by VisualDarkness Focusing most likely works like this:
1. Camera asks the lens for info.
2. Lens answers.
3. Camera gives an order
4. Lens reacts
5. Lens gives feedback
6. Camera asks for info or gives a new order
Steps repeated in different loops
I highly doubt it is a simple as just reading directions at random.
I will study the lens mounts and any info I can find and see if I can work this out.
---------- Post added 20-10-15 at 09:52 ----------
Originally posted by shardulm It may be simpler than you think it is. And you may start pondering over how a manual lens focusing works on Pentax bodies. If and when you use a manual lens the camera still gives you a focus conformation despite no communication via any contacts. Since manual lenses can be used with ease like this my hunch is that the camera does offer that simple kind of focusing ability through the lens center point restricted for manual lenses.
It may however not be the case for newer digital lenses or the ones that have firmwares in them to do the focus math and communication to the camera.
I don't think the lenses do any focus math.
I think they just tell the camera this:
Lens Model
Max and Min f-stop
Type of focus (srewdrive/motor)
Focus range (infinity - min focus)
Then the connection to the AF.
The camera can decide when it's focused and/or how far to turn the focus.
