Originally posted by wed7 by fast, I mean more DOF play, I will not swap for just 2.8's. I am looking more like F2 or faster but I do not want a big lens, even if I go the FA route, there is no option from Pentax. FA331, FA77 would still leave me hanging without a fast wide angle.
To be honest, WA even on an FF are quite limited in term of dof play.
Imagine your subject is 2 meters away:
- 21mm f/3.2 on APSC => 117cm of deph of field.
- 21mm f/2 on APSC => 70cm of deph of field.
- 21mm f/1.4 on APSC => 50cm of deph of field.
32mm on FF, same framing on FF than 21 on APSC:
- 32mm f/3.2 on FF => 76cm of deph of field.
- 32mm f/2 on FF => 47cm of deph of field.
- 32mm f/1.4 on FF => 33cm of deph of field.
To me, it is only with f/1.4 on APSC or f/2 on FF that you really get a significant difference. An FF with signa 35mm f/1.4 (23mm equiv on APSC for framing, f/1 for deph of field) + sigma 50mm f/14 (equivalent to 33mm f/1 on APSC) + 100mm f/2 (66mm f/1.4 equiv on APSC). would not cost more than the fuji route and would offer more dof play in all situations. It could be bigger.
The Fuji would not be that much smaller in the end because you would need a big heavy lense on APSC (like samyang or sigma 24mm) sure, but the 70mm from Pentax is also much smaller than a Fuji APSC tele or FF tele with longer focal length to keep the reach. Also take into account that overall the Fuji offering is more limited than the offering of Pentax, Canon or Nikon both in term of body (no FF, no 24MP, specific sensor not that much supported by photo editing softwares) or lenses (far less choice, no bargain, small used market size).
What count in the end is how important this is for you.
Is this theroretical that it exist in Fuji and you want it and may use it 10 times a years maybe or that you want to try the practice and may stop using it after a few months ? In that case, really don't do it, it is not worth it just to post a few pictures with shallow deph of field on flickr with you WA while you could have got much more subject separation with a tele shoot took from a longer distance.
Or is it really something you are after, integral to the style of shoots you are after: you really want the kind of perspective distorsion you get with a (here moderate) WA, the imersion of WA angle provide and want to avoid the perspective compression of a tele and still get this subject separation and dof control? You want the shallow deph of field and be able to be near the subject.
Then if you think it is key for your photography and style, go for it. Even if it expensive, if you are sure, do it because otherwise you'll always think you are limited, you'll be always tempted and may decide to do it anyway later. Really in that case the minimum would be f/1.4 on APSC but really better would be to go FF, so you get the best of it and don't need to upgrade again later... If finally you are wrong and don't use it that much, at least you learned it and don't feel the constant need to try or constant limitation by being limited.
